General  possible newbie
japimport
buying a multipla guide, help please
hi im tom from ireland,just saying hello,ill possibly be buying my first fiat,i have always had the japenese cars,and now its time for a change,i like the multipla as its spacious inside and something different im really tempted to buy a multipla,its an 02 one with 62,000 miles on it,had a look at it yesterday with my girlfriend,and she likes it too,the problem is i have not a clue what to check on this car,could i have some pointers,before we decide to buy it,whats the main things to look at,and to check,thanks for your help
Lots of things to check on Multi's but well worth it, very spacious car which handles reasonably well, economical (Diesel) and fairly easy to service.
Front suspension, check for play on lower wishbones as this causes front tyres to wear out very quickly. Coil springs, prone to breaking so check these.
Drop links (connecting front suspension to roll-bar) wear out ball-joints, check for play.
Anti-roll bar bushes perish, any clunking/thumping fron the front when on uneven surfaces could be anti-roll bar bushes and/or droplinks - haggle.
Discs wear out so check front discs for wear, if there's more than a 3-4mm ridge around the outside then haggle.
Plastic trim is fragile, so check boot floor trim and outer rear seat trims.
Check all seat-belts are ok and retract properly, prone to retraction being too slow.
Check the pollen filter is present and in reasonable condition.
Check electric mirrors retract and extend.
Check airconditioning works (if you've got it), might need a re-gas or might be more serious such as compressor seals gone or condenser corroded.
If diesel make sure engine pulls cleanly throughout the range and no flat spots or hesitation.
