General Pop quiz
General Pop quiz
Harllequin
Durham
Ok here is a one for you.
If you look at the engine from the front of the car. On the left hand side shock absorber pillar thing there is a small metal vented box thingy with a coil of wire in it. It has a few heavy ish guage wires comming from it.
What the hell is it and whats it for. :D
Cheers guys.
Darren
Depends which of the many things it is which get bolted to that pillar:
if it has three wires plugged into it, one at either end, and one in the middle (and 1.7 Ohms moulded into the plastic around the back, and looks a bit like the thing on the half brick in the attachement - it is indeed a dim-dip ballast resistor as mentioned by nuovapanda.
It generally lives on top of the radiator, and doesn't even get a mention in "Haynes", but is in "Porter".
The idea of "dim-dip" is that if you select "side lights" when driving along, instead of the 6 watt parking lights you get a large (dim) source of light from the dip beam, as it is fed via this substantial wire wound resistor.
It was a legal requirement a while ago, possibly discontinued now.
Failing that, if it looks like the thing under the bonnet of my (very early '93 injected, but with no brake servo) Panda ( with "Egyptian brakes" fitted to the same pillar ), and your Panda has fuel injection, it is indeed the injector ballast resistor as mentioned by Panda_Boy2.
As I understand it, its job is to limit the current into the injector (and probably protect the ECU as well).
