GeorgeDamper
Established member
My 1995 Punto 1.1 8v has recently developed a baffling problem. The idle is very uneven and after driving for 10 minutes the idle speed pulses high / low and then I get a light rattle similar to pinking. The car does not overheat.
It has 45k on the clock and has always been serviced. I have owned Fiats for 30 years and have amassed plenty of spares. I have tried the following spares from my stock:
Coolant temp sensor (blue)
Map sensor
Injector
Lambda
Coils
ICV cleaned
Timing ok
No sign of Head Gasket problem (the previous owner had this done at 35k)
No warning light
Thermostat ok
Plug leads look ok
All service items up to date
Vac pipes ok
No change to MPG
Car garaged every night
Any suggestions welcome
Map sensor
Injector
Lambda
Coils
ICV cleaned
Timing ok
No warning light
Thermostat ok
Plug leads look ok
Vac pipes ok
No change to MPG
