General  Please help!!
julietriplets
Hi, just registered, so not 2 sure wat im doin. I need help! Got a fiat multipla 2001 diesel and cant get it started. Had 2 get new indicator switch put on and now car wont start! Tried jump start, push start and got new battery this mornin! Still wont work!!! It starts then cuts of again! Sum1 suggested fuel cut off switch?? Any ideas? Really need car 2 start!
but your keys in and turn ignition on...does the little yellow key light on the instrument cluster (i think it also says CODE on the light) go out after couple of seconds. if not you have a problem with the transponder key (immobiliser) and may need recoding (FIAT)
If it is the above, you should be able to perform the emergancy start procedure... Follow the "in an emergency" section (i believe) you can input the code using the clutch and accelerator :)
