yellowbelly
- Joined
- Feb 2, 2009
- Messages
- 4
- Points
- 1
I have a 2004 Punto Dynamic 1.2 8v. It started to have difficulty in turning over properly about 3 months ago and had a new battery fitted, and alternator checked, which is fine apparently. Problem sorted, but weeks later started again. The car seems as if the starter motor turns very slowly, but used to fire up the majority of the time. The problem was persistent when cold. An auto electrician said it was a lazy starter motor, so I had a new one fitted about 3 weeks ago, but problem came back. Went back into the garage and had all connections and earth cables checked, apparently fine. Even isolated the starter by earthing the unit itself, still not turning properly. Battery is good by the way, even when it has problems starting still reads full, so dont think it is that or alternator.
Problem is so bad now that it will not start at all unless it is jumped by a power pack. When I try to start it, it just dies and the clock resets and the dash click and goes mental!
Also, had an inspection done on the old starter motor, and it appears fine, but for a bit of clutch dust.
Please, please, can anybody help me. Is this a common fault?
