- Joined
- Jul 28, 2018
- Messages
- 137
- Points
- 97
Hi, it's me again. Now when major issues are repaired, I wanted to fix some smaller ones on my 2003 1.9jtd 85kW 5door Stilo.
1st problem is play in gear shift lever. It moves like 1,5 cm form side to side. Any way to make this better without changing whole lever? I saw plastic bushing on bottom of gear stick on other cars, but I can't find that piece for Stilo. Does it use some other mechanism? https://imgur.com/gSoSxSn
2nd I have broken piece that holds hood release lever. How do I remove it? I tried unsrewing that one screw, but it's held by cable. I don't want to damage anything else.
3rd Boot does not open completely, it goes to about 50% and then slows down and moves very slowly up. I changed both struts for new (Magneti Marelli), but it did not help much.
4th Should be this gap at bottom of front glass? (Now it's full of tree mess, don't mind that) Is it for water drain, or should I seal it? https://imgur.com/UJQxBLL
Thanks for any help
Thanks for any help
