(Pictures Included) Pink Coolant Leaking/Sprayed around Engine Bay
myfirstpunto
I have a Fiat Bravo 2007, Which has done around 90,000 Miles. It is a diesel Engine, which has been well kept and serviced.
Recently I have noticed a problem when I opened the bonnet and discovered Pink Coolant which has been sprayed or leaking from somewhere I couldnt find where its leaking from. I have topped up the Coolant again.
Thanks for Reading.
Must be rad or one of the hoses as the front of the engine is covered. Im guessing the water pump is driven by the cambelt on this engine ?
Is there any coolant around the coolant bottle itself ?
There is nothing around the Coolant Bottle, I was thinking it could be the RAD or one of the hoses, Shown in the last picture. How much would this roughly cost to fix?
Depence rad could be a bit more expensive than a hose, I would be thinking 200 at a good independent garage max.
Best to take it to get a looked at properly.
Thanks, Ill clean it up 2morrow and let it run for a few hours and see if anything leaks out.
