PICS OF A FAN TEMP SENSOR NEEDED
S
scotty
Can anyone put a pic up of a temprature sensor for the 1.9JTD?? the one that tells your cooling fan when to kick in, What i have been told is the temp sensor is very diffrent to what i saw at the patrs shop.
I tried searching in online shops but dont get anything
Cheers Scotty.
sorry link din`t work, take the "look here" out and it might work lol
Thanks for trying,but im just getting page error on that ?????
Scotty
soz mate just look on shop4parts thats where i got it from £10 or there abouts, and a picky too lol
I tried there,what did you type into the search box??
Cheers scotty
Yep thats what i saw at the parts shop,ware does it go and is it easy to do?? is just a case of take the old one out put the new in??
Cheers Scotty
It goes in the radiator. And yes its easy to do. May need to fill the engine coolant up abit afterwards.
So water will come out do i have to worry about air getting in the system??? whare abouts on the radiater does it go??
Cheers Joske scotty.
If i remember correctly it should be on the lower left hand corner as you look down at your radiator. Just look for a plug connected to your radiator. It'll be the temp sensor. Water will run out, best be as quick as you can then just top it up, as you've only drained the radiator, not the water within the engine. Also there should be a bleed screw on top of the radiator, to let excess air out.
Please be sure before attempting to change the sensor. My brains a bit dusty on this matter.
Made in Fiat
M
2
467
M
M
431
M
M
8
627
M
1
7K
Dark Lurker
L
455
L
