Technical Permanent live fuse??
HughJarsse
Established member
Dahn in Darset!
OK, hoping someone can help me out here.
Have a dashcam (xmas pressie!!) which needs a constant 12v supply, as well as a switched supply from ignition and earth. Easy to find a switched fuse to piggyback off in the fusebox, (cigar lighter!) but, is there a permanent live fuse that I can piggyback off of in the fusebox, without having to do a complete run right back from the battery? Earth is no problem, just the permanent live. Seems a lot of work to run from battery to the dashboard, if there is something I can tap into.
Searched the forum, and the manual and can't seem to locate anything that would be permanent live from the fusebox. Any help gratefully received !!🙏
