Passenger window is slowing down...
P
Pete
Hello all....I have noticed lately that the passenger side window is taking its time going up and down.The driver side is fine....could it be that the window on that side is dirty....any thoughts???
I have noticed that with the passenger window in my car, yet if you use the passenger side button the windows go up n down at the normal rate!! strange, takes an eternity if i use the driver side button
Fiat electrics, wonderful things
mike
see if there is more play than usual with the passenger window by moving it side to side. it may just need tightning... i had a similar prob... just tighted it and sprayed some silocone along the runners.
Re: Re: Passenger window is slowing down...
Probably just cold witer weather
Heaters
Lights
Stereo
Rear heated window
All = Battery drain
Turn everything off and try it, it will probably work normal.
