passenger window goes up really slow!
R
ryan
as title says, its taking an age to go up! so tomoro im gonna take it out and clean whatever needs cleaning, by the way, what needs cleaning,lol?
I have the same problem :) with my passanger window. I mean it doenst go really really slow but my drivers window is way faster :)
Is this common bravo problem ?
i think its a common fiat problem, my m8 has the same in his punto!lol, im gonna clean watever needs cleaning tomoro n c what happens
mmmmm
same in my brava ......dont want to take doorcards off so im gonna empty a litre of oil through whatever gap itll fit in ........thatll do it
Re: mmmmm
lol, well il post a thread letting ppl no how it went on, then u dont have to waste ur time if it dont work
Re: mmmmm
Had the same problem with my windows. What you need is Maplin part N71AN - Silicone spray with PTFE. You can buy the stuff on the Maplin website. Once you havee it:
Wind the window down
use the straw to spray it into the gap in the rubber strips around the edge
of the window openning.
Bingo, too much speedy windows.
Re: mmmmm
You'll find it costs a fortune if you get it from Maplins (if it's all you're buying) cos the postage etc added on. I got some from motorspares, but MAKE SURE ITS SILICON, as that's best for lubricating agains rubber.
It helped loads (had to spray quite a bit in though) but about 6 months down the road it now needs doing again.
Thanks for reminding me!
Ben B
Re: mmmmm
Isnt there a guide on here for that? ;)
Oh yeah, here it is :)
Slow Side Windows - Also how to replace the electric motor mechanism.
2 options
Firstly is Toms way (and easiest)
Second option
This is easier with the mechanism removed
1. Remove the door panel (see above)
2. Take off the inner lining
3. Unclip the window to guide puller clip - its in the middle of the window and is a bit of a fiddle - it is a sort of plastic loop, you may need to use some pliers.
4. Unplug the wiring loom to the motor.
5. Undo the three mechanism retaining bolts then wiggle it about and extract it through the apperture. You can leave the window in place.
6. Clean off the centre runner with some degreaser and then regrease using a light grease.
7. You can check the mechanism off the car by simply plugging it back in. You may also need to regrease the worm behind the cover.
8. Put it back into the door and bolt it back up.
9. Reclip the window to guide.
10. Spray some silicon based lubricant into the side runners as well.
Next time I do one I will take pictures as it is a bit awkward.
Daz
Free X-box 360! All you have to do is register and send to friends, not a scam!...
http://www.consolegrab.co.uk/?r=16309
Re: mmmmm
£3.50 :D i reckon you could manage to save up for it ;)
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
Member Page
Re: mmmmm
I think he meant expensive if you only buy that from maplins online...
As you would pay £3? postage making it £6.50 ;)
Daz
1
7K
Dark Lurker
C
3
778
Tommy K
T
W
914
wakka
W
L
1
746
Tommy K
T
M
1
533
Dark Lurker
