freddyokel
- Joined
- Jun 26, 2015
- Messages
- 18
- Points
- 59
So, I've got an airbag error. No lights lit but an error none the less.
The error occurs when I try to disable the passenger airbag (using the key switch in the drivers side cubby).
The yellow disable light does not come on and the airbag ecu shows '14 - Passenger airbag exclusion switch - Plausibility - Present'.
I've had the switch out and apart and it's clean as a whistle and switching between 100 and 400 ohms perfectly.
I'm wondering if this is similar to the problem that Mk2 Puntos get and if the fix (a loom with an extra earth) would be the same. However, I'm guessing the Punto loom won't fit as both the switch and the ECU are on the passenger side in the Punto.
Any ideas? The car is a '10 Multipla M-Jet Eleganza.
