Part Numbers Required
W
Wimmy
Can anyone with the Fiat CD please give me a few part numbers for a 1999 80(1.2) SX
1. the plastic door sill runner thingy for the passenger door
2. A Towing Ring
3. A 'Bravissimo' tail badge
Thanks in advance
Her you go Bud
1. 735249279 / 735249281 depending on what side I presume £11.50ish
2. 7774731 £3.50ish
3. 46535859 £4.50ish
Nige
Re: Her you go Bud
Ta Nige, you're a star.
Ordered!
While you're here. I will be replacing my Bravo badge with the Bravissimo badge when I get it. On the bravo-guide it states removin with hot water and a spatula as its only glued on. I'm sure I read on here recently that the badges had a nut on the otherside. Which is correct? (I presume the guide)
glue
Badges are definitely glued on. I used a hair dryer to remove the main badge, then a rag with some white spirits and a lot of elbow grease to remove the remaining glue. (getting the glue off is the hard part! took me over an hour.
Re: glue
If you use a kettle of hot water and a plastic spatula the rear badges come of in under a minute including all the glue! I know - I did it that way which is why I put it on the guide like that.
All that ball ache with hairdryers, dental floss etc obviously works, but you can do it a lot easier!
Longest part is waiting fro the kettle to boil oh and having to clean the car after as well as the only clean patch is where the badge was.....OK i didnt bother doing that either!!!
Nige
P
7
670
S
R
2
474
R
M
7K
marko
M
S
3
520
Dark Lurker
M
4
365
M
