General Parking lights
Turning ignition to "parking position" (when you push that "button" and turn key left to end) and only front right parking light is on with both rear parking lights - is this allright?????? or front left park. light should work too?????
Dim Dip.
In the first light position the dip beam comes on, but dimmer than normal.
In the 2nd position the dip beam comes on to full brightness.
Dim Dip.
yes, in 1st pos. there's only parking light on(that small bulb inside headlight), on 2nd there's dimmed light/dip beam on-everything is working great, both lights are working on both positions
but when I switch ignition key to park. position(yes, there's one more position that youre not usualy using), there's only left park. light in front working
its not important, and mostly youre not using those lights, just want to be perfect :D:D
Dim Dip.
After 2 years of ownership i've only just clicked. This explains how the "sidelights" are soo bright and get brighter after you turn them on!!!!
:eek:
away from parking lights, i dont want to make new thread, so it will be here,
i need to connect light into boot, it will be connected to earth pole through door push switch(used for alarm), buit there's problem where to connect positive pole???? is there positive pole somwhere near boot or i have to lead cable to fuse box in front... ????
One more thing, neon lights inside car under dash - want to make them work when door will be open(this is simple), but also when I switch on inside roof light-only way is to connect cables directly to light switch on roof??????
