Hi all ,now a owner of a Panda Super 1000 ,I never knew that a thing so small could have sooo many faults ,still not the cars fault ,just the 5 not so careful pervious owners ,still working my way though them thanks to this really useful forum, so as a thank you decided to give some info back! Hope if benefits someone thanks…..oh and loving the “old school” choke fantastic!
Panda, 1000 FIRE, 999 cc, 1986-, Engine Code 156A.2000
Ignition data
Panda, 1000 FIRE
Ignition system type: CB
Ignition coil make/type: Ma/BE200B
Supply voltage: 11 - Volts without ballast resistor
Primary resistance: 3.1-3.4 Ohms
Secondary resistance: 6500-8250 Ohms
Distributor make/type: Ma/5181A
Contact breaker gap/air: 0.45 mm
Dwell angle: 51-55 Deg
Ignition Timing - unleaded: 2 2/850 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 2 2/850 Deg eng/rpm (without vacuum)
Timing mark location: Flywheel
No 1 plug location: O/S/F
Firing Order: 1-3-4-2
Spark plug make: Bosch
Spark plug type: FR7DC
Electrode gap: 0.7-0.8 mm
Fuel System
Panda, 1000 FIRE
Fuel type: L/U
Fuel pump type/pressure: Mech/0.2 bar
Engine idle speed: 850 50 rpm
Fast idle speed: n / a rpm
CO level at idle speed: 1.0 0.5 Vol %
Engine Data
Panda, 1000 FIRE
Valve clearance - inlet: 0.30 c mm (cold)
Valve clearance - exhaust: 0.40 c mm (cold)
Compression pressure: n / a bar
Oil pressure: 3.5-5.0/- bar/eng/rpm
Radiator pressure cap: 0.98 KFB240 bar/type
Drive belt 1 - size: 9.5x675 KDB675 mm/type
Drive belt 2 - size: n / a mm/type
Electrical System
Panda, 1000 FIRE
Alternator output: 45/2500 Amps/eng/rpm
Regulated output: 13.7-14.3 Volts
Battery: 12/30 V/Ah
Starter motor make/type: Ma/E95-0.8kW
Other data
Panda, 1000 FIRE
Clutch operation type: Cable
Clutch adjustment: As B.Pedal mm
Cambelt failure: Damage
Cambelt Part Number: 7554701
Tyre pressures: 2.0(28)f 2.0(28)r bar (psi)
Ignition data
Panda, 1000 FIRE
Fuel System
Panda, 1000 FIRE
Fuel type: L/U
Engine Data
Panda, 1000 FIRE
Electrical System
Panda, 1000 FIRE
Battery: 12/30 V/Ah
Other data
Panda, 1000 FIRE
