Sweetsixteen
Established member
- Joined
- Jul 7, 2014
- Messages
- 1,109
- Points
- 205
My steering began pulling to one side, but not all the time. Tracking was checked and adjusted, and was fine. Sometimes it pulled, sometimes it didn't. I thought the sensor in the column was beginning to go home, and began checking out prices. I also checked all the wiring, to make sure there was good electrical connections.
Just been in France for a few weeks (still there), and I found that there was a worn joint on the front suspension, which 'clicked' every now and then, causing the above steering effects. Will check it out when I get back, but it's either a stiff, worn track rod end or wishbone bushes. Either way, the joint must be dry, worn and very stiff, so that it only goes 'off' if I brake hard on full lock - forward or reverse.
My indie missed it two weeks ago at Mot time!
Worth checking suspension wear if your steering plays up - cheaper than buying a new column!
