Technical Panda door handles
I have had trouble with our 169 boot release. I removed it and it was a buildup of very fine dust and dirt where its hinge pivot fitted. It was so slight I woulnt have believed it would cause the problem. Its been fine since cleaned. Door handles are fiddly things but other cars Ive done have been straight forward. The worst bit is usually repacing the damp seal behind the door card. Get some strip mastic from a caravan dealers to refix it. it works and saves time and distress. Replace the plastic sheet if its ripped again not worth mucking it up for a fmall outlay.
First try a good dose of WD40 Silicon spray (yellow can) It works wonders on sticking plastic things.
Hi thank you ever so much for your help it worked wonders I’ve owned the car how nearly a year other than the drivers doors the rest all were sticking I sprayed them left it for a day went back and done it again and now they all work
