Technical Panda cross wheel specs
mosfet
I cant seem to find the width and offset (ET) of the panda cross wheels. Anyone know?
Thank you for the replies. I had a suspicion they were the same on the regular 4x4 as the cross, but since the tires are different, I had to make sure.
  • 2009 Fiat Panda Cross wheel_6Jx15H2-24 + 2013 Panda 4x4 MJ wheel_6Jx15H2-35--.jpg
Can you confirm which is correct - the photo captions are the other way round to what you wrote in the text. I believe 2013 4x4 should be 35mm offset?
Apologies, you are quite right. The photos and captions are correct, but my text was wrong. Offset is 24mm on the 2009 Cross, and 35mm on the 2013 4x4.
Mods/Admin - can somebody please amend my previous post (can't find the edit button anywhere).
It's been a long time since anyone posted on this thread but here's my pennies-worth and question:
I've just been quoted a wheel size for a 2017 Twinair Panda Cross of 6Jx15 H2 ET30 by the Fiat on-line Live Chat. Can anyone confirm that this is actually correct as all of the on-line tyre/wheel suppliers seem to indicate its a 35mm offset.
They could have change it, because the 4x4 use a 175 tire and the Cross a 185 tire.
Following up again on Fiat LiveChat I have been given the following information by Fiat - "the 6Jx15H2 ET30 is for the 185/65 R15 88H tyre, ET35 is for the 175/65 R15 84T tyres".
Its just that when i look online for wheels and tyres, none of the suppliers seem to be up to date with this info. and therefore I can't select the right combo. on the screen. Guess i'll have to order by phone!
its a very old thread but maybe someone will check it again. the new panda 4x40°, only sold in Italy, Germany, Belgium, is actually a Cross but comes with 175/65 on 6x15 ET35 rim. I was wondering if its just a matter of tyre size or maybe the subframe interference that required et30
