cube
Hi, newbe here in need of help and moral support.
The car in question is my daughters 1992 fire clx, TLF32 carb and mechanical points. The car intermittantly cuts out usually after slowing down at a junction or after turning the engine off then attempting to re start a few minutes after popping into the shop. This started about 2 months ago when it would happen say once a week, always started immediatly after. This last 2 weeks it will run for 10mins or up to a couple of days then stops / cuts out usually with impatient que behind and progressivly needing more time to get started again.
The car runs well 40+mpg, accellerates and ticks over well, will cruse at an indicated 80 for 20 miles no problem.
The vac advance seems to be holding vac well, points are fine, good spark, fuel pump pumps well, had the carb top body to bits the float and needle seem fine blew out the jets I could see dosnt seem to be flooding either.
The problem I have is I never seem to be around or the fault dosn't remain long enough to diagnose as so far it runs again soon after it happens.
One time it happened when I was in the car I opened the petrol filler cap (suspecting a blocked vent) and I think pressure was released rather than vac in the tank.
Any suggestions much appreciated before I have a Basil Faulty moment with a big stick :bang:
