Technical P0089 fault code.
CharlieC
Hi all.
i have a Ducato 2.3 130 2007
Can anyone help me please. Engine started cutting out while driving, no indication just EML came on them cut out. Code P0089 was present, fuel pressure regulator. This was changed ( this is on rear of fuel pump )
Seemed great for a little while but now she is fine while driving however when started from cold she ticks over for a minute or two then cuts out, she will restart and does the same again and again but when driving she good, she doesn’t cut out at traffic lights etc.
same code present P0089
Any suggestions greatly received.
Hi all.
Hi did you sort this issue as mine is chucking up the same code p0089 but also p0090 . next move is to buy the pressure sensor on end of fuel rail but don't want waste money if it's not going be that
