Technical  overboost gauge problem
asgharan
Hello, I've a tempra 1.9 TD SW and the overboost gauge is not working since 2 weeks and I could not find why. The overboost is working cause I hear it.
Any ideas please, a documentation about that ?
Thanks in advance !
Ah and I've check this http://www.brickfieldspark.org/temp/fiatmanuals/temprainfo.htm
but found nothing in to help me.
ps: sorry for my english, i'm french
Hello, I've a tempra 1.9 TD SW and the overboost gauge is not working since 2 weeks and I could not find why. The overboost is working cause I hear it. Any ideas please, a documentation about that ?
Thanks in advance !
The boost gauge is connected to the injector pump by a small rubber pipe. Usually the pipe splits where it connects to the pump or the boost sensor. The boost sensor is in the front wing under the battery. I have had this problem several times on both my 1.9Td's and it has been the pipe every time.
You can shorten it a bit to get to a good bit of pipe but I would go to your motor factors or garage and by a new bit of pipe. The pipe can be bad at either end.
Picture here - www.brickfieldspark.org/temp/fiatmanuals/dscf1874ashrunk.jpg
Thanks again it was it, I've just shorten it, plugged it and it works. So simple when you know !!
