Your original screen grabs show the actual turbo control position not tracking the desired turbo control position, and they show the expected deviation that corresponds for the over and under boost conditions. This indicates the VGT vanes are not at the desired position being called for by the ECU. Were those screen grabs captured before or after you replaced the mentioned components? If after, then either the drive to the VGT or the VGT itself is not operating correctly (either a vacuum issue, or drive to the turbo control solenoid from the ECU, or a sticking turbo).
