General Over fuelling on cylinder 3
j1p2w3bikes
Hi all getting a odb2 code "P0203 injector circuit open cylinder 3" and black matt sooting on the sparkplug causing the car to run rough, its been in the garage a few times for this resulting in new coil pack and throttle body cleaned out and over a£400 bill i imagine they have cleaned the spark plug each visit but each time after about 2 weeks it pops the code up and starts running rough again, i was hoping i could get some advice on swapping injector 3 with injector 2 to see if the issue follows i am no mechanic and have never touch anything to do with fuel rails or injectors so all info would be appreciated to do this,thanks
If you don’t know what you’re doing then give it to a garage, seems likely it would be a bad injector if everything else ruled out, just make sure you’ve tried everything else first.
I believe the injectors need coding to the engine ECU so is likely a job for the garage if you don’t have the means to do this yourself
