frankharrison
Hi can anyone help with my 2005 Multipla?
I've a weird problem. The outside Temp Sensor sometimes goes mad. Most days it's ok but on some it will read -30 or more then creep up slowly to the correct temp. It has also gone to+ 30 or above slowly going down. The highest I've recorded is +66 and lowest -66.
Sometimes it happens on sharp bends in the road.
I also have the dreaded "Air Con Fault" come up every so often, then it's ok for days.
Is there a wiring problem? It did work ok when I first bought it.
How do you disconnect the socket at the door to check the wiring?
Thanks for your help.
Frank
Frank
