Technical outer CV joints compatibility between Mareas
lukish
Chesham, Bucks
I'm trying to buy the correct outer CV joint for my Marea 1.6 SX 2001. There are several candidates on eBay, but when using the automatic compatibility check, it appears that some CV joints are only compatible with Mareas 1.6 built up to 1999, while others with those build after that... And of course there does not appear to be compatibility with Mareas other than the 1.6 engine.
Does anybody know about the compatibility please?
Thanks!
On 1.6 you can use brava/bravo parts, even the shafts are identical (only applies to 1.6 as they share the same partnumber on eper, on other engines they do not).
