Technical Original Technical Service Manual
ser907
Hello everyone,
i would like to download the original technical service manual for FIAT Punto Evo 1,4, 8V 2011 but only thing i can find is a Seichento manual with a chapter with FIRE engines.... Unfortunately, the FIRE of Punto is not completely the same as for these old cars, namely, timing belt change procedure is absolutely different.... Has anyone any idea where i can get the Punto service book?
many thanks in advance,
Sergey
No, i would rather have the original manual like they use in an official service. It could be in english, german even italian....
they dont exsist....
well the dealers use a program called E-Learn this used to be in CD form till 2010, however with the evo and the turn of 2010, fiat moved it to an online subscription service. You used to be able to get a subscription to this service but the price made it a tool only for professionals.
The haynes manual is perfectly good for a home user.
Ok, clear... But maybe there is some cracked way to get it, like, for example, cracked EPER for searching spareparts numbers....
So, thanks a lot for the hint. I've downloaded the eLearn for Grande Punto 2010 and it it's nearly the same as for Punto Evo 2011.
Please please please could you post a link to the elearn section for a 2010 evo punto. I have had a good look around the site but cant seem to find it, also a diagram for earth location points please.
The lad has ordered a haynes manual 5956 for his punto but that will only tell us so much/little.
Go to the Grande Punto Forums and then click on the download tabs at the top this will give you the Elearn files for the grande, I however would not follow them for the EVO as there where a lot of changes with the revamp to the EVO. especially with a lot of changes to the electronic systems.
cheers andy will go and have a looksee.....lad has ordered a haynes manual 5956 from amazon, but they are sometimes really crap at sending stuff, they say they have it in stock but dont! been waiting for 2 years for a particular calander for xmas presents, still waiting......
