One last bug on my Bravo 1.6...............>
C
Craig S
The car runs thanks to Toms crankshaft sensor idea. But the engine is only firing on three cylinders. I've checked spark plug etc etc, ht lead etc. We think it MIGHT be the injector. The injector light is on and the spark plug is black and the others aren't. How do I go about cleaning this injector to get the cylinder firing again? Or am I going dowwn the wrong track here?
Any help is appreciated,
Craig S.
tom i heard on the 1.25 zetec engine in the ford festa u can add a fith injector. could u od the same on these engine and wat does it do anyway??
Smee
Why not add another 4?
Tools required...
1 Drill
1 Drill bit small
1 Drill bit Large (Same size as injector)
1 McMuffin
1 McMilkshake
4 lengths of fuel pipe
Daz
this is a genuine question.
and daz u gonna sort me out or not then chap. i not sure wat to do with my dash sure u can think of something ;) . ill buy u some nuggets when i come over and mcflurry???
Smee
I really havent got the time...:(
I can help with idea's, but not much else at the moment...
Daz
will most prob be after xmas mate. but not to worry. ill get ferry secure guy to do it
Smee
Tools required...
1 Drill
1 Drill bit small
1 McMuffin
1 McMilkshake
ROTFLMFAO!!!!
I'm so glad I'm not American. I'd never have got that if I was!
Shabash!
Now partying with Yul Brynner
http://www.billhicks.com/
http://www.geocities.com/ozrictentacles_web/
thanks tom for a proper answer. so no performance gain then
Smee
Not on an engine where the other 4 injectors are capable of supplying enough fuel. Too much fuel = less power.
The problem with that is the other 4 old injectors are just as likely to be blocked now that the inlet manifold has been off and messed with. The reason why we had to take the inlet manifolds off each engine was due to the stupid fuel in tube going under it with a bolt under the manifold meaning it was impossible to get off otherwise. So my blocked injector is likely to have been caused by us, it was probably working fine until we took the manifold off! But we had no choice. Is it worth trying some of this injector cleaning fluid stuff or not? If so any recomendations of which to use would be appreciated.
Craig S.
Its not blocked, its ****ED, broken, nackered, no good, its an ex-injector ;) Bin it. use the other ones.
Injectors have filters in them to stop grot blocking them when you handle them. They ain't as delicate as people think.
M
7K
M
F
7K
F1-ANG
F
E
1K
E
K
2
1K
Dark Lurker
