General On Closer Inspection
Wrexham
The panda is gonna be a winter project. Will update if and when I get it completed. As I can only work on it at weekends it gonna be a long time :(
A few rust issues
:eek:
Underneath of boot seal will need replacing as it rusted away
Drivers sill flappy bit about 3" at front and back have gone and is held there by the underseal
Apart from these bits the car as no more rust :D
Excuse my technical terms. The rod thing that goes into the box that like an udder is leaking. How do I stop it. Pics may give a better idea
I need a new exhaust as from the manifold onwards it rusty and rubbers need replacing
Petrol tank needs replacing
I think this is it for now, wish me luck as I don't really know what I'm doing :eek:
Unless the exhaust has holes or is blowing leave it alone. They often look like they are about to fall apart but often go on for years.
Again with the fuel tank, unless its leaking, best to hand wire brush it and slap on some hammerite.
I have not really checked exhaust for holes. It don't sound like it has any, just looks like it on it last legs. May just replace the rubbers, will count the pennies after I have sorted the rust.
The tank ain't leaking, just looks ugly
If you petrol filler pipe has no damage then i will go halves with you Gaz as the tank costs 50+10 postage but it comes with a new connecting pipe... my 155.80.13 took a chunk out of mine on the standard rims... but the alloys seem to be clearing much better.
PM me if it's do-able and we can set something up.
mine failed the MOT on the tank so it was a must buy for me...
ah gaz ,i'm sorry your panda's showing a bit of rust , but dont worry its obviously a 'true panda':D
just think how great its going to look in the spring (y)
gina XXX
Thanks Tony, I will have a look at the pipe, just in case it is or shows any sign of failing on me. If it is fine then you got yourself a deal (y)
I forgot to say that both the doors have had it :(, so either gonna try find some decent ones, or go see if I can get new metal on the bottom of the doors
Do you think I should invest in some new window, door and boot seals? because the original ones are obviously not working :D . Is it possible to get hold of new ones?
Good luck finding decent doors! Especially in Sisley colours! I've got 3 non rusty doors - two in black and one white one. but none are 'perfect' i.e small dents etc..........
I've also got the two red 1000s doors off red but they both have very rusty bottoms.
Best idea I think is to re-metal the botom of both doors and Black up the bottom of the car up to the Side trims!
Yes you can get all new window and door seals but I don't fancy the Fiat prices! I might have some decent ones in my garage off a nice 1000s I strippedin Devon a couple of weeks ago.........:)
...new exhaust system? Flash has one! £119.oo fitted at kwik-fit
i bought a new boot seal recently ... cost about £25 i think.
i've got a bunch of second hand ones ... doors and windows... but not much else.
really... the whole lot I got quoted by them yesterday
front section 62.60
mid section 44.30
back section 70.70
1.00 dispposal of old unit.
all prices with fitting included
needless to say i'm sure people can do better than this.
I would get a s/s made up. I know a guy who could probably do me one for £100. The car would rot around it but at least I would have a shiney exhaust.
I broke the plastic trim that goes up drivers rear quart, it got the canoe badge on it. Is this trim on all pandas. Or just special ones, the canoe looks like it is just a badge so I will carefully take that off, if I can
I should stop looking at the panda cause I found something else I need to fix, a small rust spot around the windscreen. It looks like the glass has been replaced and they have probably caught the paint work casuing it to rust over time. It only looks surface but after the "easy" job I undertook yesterday I am expecting the worst.
front section 62.60
mid section 44.30
back section 70.70
That's shocking!!!!!!! someone is having a laugh!:eek:
Flash was fitted out in Weymouth.....
but yes - get the seals sorted out..........
You have to take the badge off to get at the bolt or clip that holds the trim on so you can use any side trim off a panda and then just refit the canoe...
https://www.fiatforum.com/panda-classic/55500-dont-hoke-things.html?highlight=juppy+rust
Rust round the windscreen.... :cry:
Jim
Looks like i be taking the interior out to have a look. them pics scare me :eek:
I attacked panda with a dremel and done this
I hope I have done the right thing. I wasnt really sure what I was doing
Now I have to put some rust killer on it, can it wait till next weekend?
oh it's all fixed now... Except I've not put the car back together yet... :eek:
As long as you've not got rust in the chassis rails everything is fixable (or so they all told me when I came on here crying me eyes out..:p )
Jim
