Hellcat zombie nation Parked in the garage Written a guide Joined Jul 8, 2005 Messages 28,510 Points 5,372 Location on the A684 Oct 21, 2005 #1 Thats from a UK spec car with what looks like 1890 miles on the clock!
Trancendental Patron member Parked in the garage Joined Mar 29, 2005 Messages 5,034 Points 806 Location NW London Oct 21, 2005 #2 were the wheels on the ground in that photo??
The Negotiator :) Joined Apr 21, 2003 Messages 22,169 Points 3,120 Location Nottm Oct 21, 2005 #3 To check whether it is genuine you can check the RPM. If you assume they have the standard wheels on and have the gear ratios/final drive
S sumplug Established member Joined Apr 19, 2005 Messages 3,244 Points 399 Location sunny Spain Oct 21, 2005 #4 Hellcat said: Thats from a UK spec car with what looks like 1890 miles on the clock! Click to expand... look at this carefully.the revs are 6500,speed 150mph.gearing then approx 23 per thousand.but why is the odometer reading zero.dont think the gearing is that high on a 16 v.can someone confirm top gear gearing.
sediciRich Member Joined Mar 21, 2005 Messages 601 Points 97 Location Glasgow Oct 23, 2005 #5 the other half is missing off this picture, it shows the oil pressure at 0. Seen it before, although my tipo turbo could produce that for real. rich
OP OP Hellcat zombie nation Parked in the garage Written a guide Joined Jul 8, 2005 Messages 28,510 Points 5,372 Location on the A684 Oct 23, 2005 #6 sediciRich said: the other half is missing off this picture, it shows the oil pressure at 0. Seen it before, although my tipo turbo could produce that for real. rich Click to expand... Thanks for clearing that up Rich. Nearly but not quite 150 for the tipo!
Trancendental Patron member Parked in the garage Joined Mar 29, 2005 Messages 5,034 Points 806 Location NW London Oct 24, 2005 #7 there is a guy round here with a modded White Tipo which could do 164mph. looks standard but the enginey bits aint
