Technical OMG! It goes how fast?!
on the A684
Thats from a UK spec car with what looks like 1890 miles on the clock!
To check whether it is genuine you can check the RPM. If you assume they have the standard wheels on and have the gear ratios/final drive :)
look at this carefully.the revs are 6500,speed 150mph.gearing then approx 23 per thousand.but why is the odometer reading zero.dont think the gearing is that high on a 16 v.can someone confirm top gear gearing.:)
the other half is missing off this picture, it shows the oil pressure at 0. Seen it before, although my tipo turbo could produce that for real.
rich
