Stuck. got most of the stuff i can reach off the engine.
Turbo is attached to the exhaust.Exhaust is attatchedto a pipe with a pipe forthe egr. got the egr off.the pipe bolts are undone. but they cover the last bolt for the pump. cant take the boltout unless i move the egr pipe. cant remove the egr pipe becuase the pump has a alloy t pice out of the bottom covering the egr pipe.
STUCK. Any ideas.
Also do how do i remove the high pressure injector rail. its covering the bolts for the inlet and the bolts for the injector rail appear to be under the inlet manifold.
cant seem to reach the back of the high pressure pump without removing the inlet cant get to the inlet side of the high pressure rail without removing the inlet. cant get the inlet manifold off because the bolts are behind the high pressure pump. must have to remove the pump to remove the head.
:bang::nutter:
STUCK. Any ideas.
