Technical Oil Pressure. Ducato
ninian324
Hi, If I was to place an Oil Pressure gauge in place of the switch on my Ducato 2.3 / 150 what pressure would I expect to see.
Hmmm interesting question , being honest i don't know the exact answer . However 25-65 psi is generally seen as acceptable , though many manufacturers state that an engine should read around 30 at idle , rising to 60 when running at higher speeds .
My mothers mini has a factory pressure gauge fitted (98 Rover Mini) , that reads 60 psi at start up , falling back to 30-35 at idle as the engine warms . Poking the engine with a stick does raise that , but nowhere near the the top end stated .
Yet interestingly the pressure given for my x230 are 11.5 at idle , rising to 56 psi at 3800 rpm ? .
Personally i would add both via a tee bar , and maintain the pressure switch in the circuit , for that sort of belt and braces touch !
same problem 2021 ducato 140 low oil pressure warning when left over night about 4 months ago then done it again 3days a go my truck done 170,000miles engine sounds good spoke to this guy 07508402985
the switch would still need to be in place or ecu would pick up fault pressure at idle 30 at bottom sensor 70 at top sensor
