Marvin 1973 500
- Joined
- Feb 3, 2015
- Messages
- 12
- Points
- 3
Hello all. I am having a frustrating time trying to eliminate an oil leak at the oil pan gasket. I have replaced the gasket two times, and it still persists. It originates along the side which is behind the flywheel. When it leaks, the oil is blown around by the flywheel and the cooling system. The transmission bell housing area will eventually get a coating of oil. Not good to have in the clutch area.
I clean the bottom of the engine case with solvent, as well as the pan contact area. I checked the pan for flatness, and it seemed OK. The bottom of the engine case has a few scratches from the previous owner, so I have been using a thin film of black RTV sealant on the engine case surface, both sides of the gasket, and the pan contact area. I am using those thick, (tan centered) spongy type of oil pan gaskets. I tighten the screws evenly in a cross pattern until they all seem to give the same tightness. I am careful not to go too far, and squeeze the gasket so that it appears to bulge out.
All is OK at first, but then the leak starts in the same area after running for a day or so. The drips on the floor originate along that flywheel area. When I check the screws, they are no longer snug, and I have to tighten them again. It seems like the gasket has yielded?? I am using the oval washers and a split washer on top of that, so they should not loosen. The leak slows a little bit after retighteneing, but eventually it is back to the same amount.
I have used a rubber type, or a paper gasket, on other engines, along with the RTV sealant and have never had a serious problem. If a surface had scratches, I filled them in via epoxy and scraping off all excess with a razor blade. Gets me back to a flat surface. Has anyone else had this kind of problem? Have you used a paper gasket or other material with any success? I have one new spongy gasket left to try. Thanks in advance.
