oil leaking
oil leaking
M
Misa
Hi. I have Fiat Bravo 1.8 GT '96 and problem with leaking oil under camshaft cover. I have changed main seal but after about year, leaking is repeated.
Is that oil leaking connected only with seal?
Do I have to look for something particular when buying seal?
Is a breather pipe, on the camshaft cover, simple “Y” pipe or have some mechanism in it?
Am I a to ambitious when expecting from Italian car to have no leaking seal after a year? :)
Best regards, Misa.
When it stops leaking is the time to worry. If its leaking then you know there is oil in the engine. :)
How much is it leaking? Just a little drip now and then or is is quite serious?
Re: Re: oil leaking
Not serious. Just annoyng. And messy.
Leaks
Replace the top gasket lah. And of course the spark plug oil ring.
Regards,
Syed.
S
1
7K
Streak2013
S
M
2
743
Dark Lurker
J
1
1K
Frank
F
S
1
558
K
