Technical Oil Grade ??
Lets not forget 1 very important point, No one is going to recommend using the asda oil because no one other than asda is able to sell it. The important think is that it meets or betters the spec needed which it dose and is the correct grade. For me thats good enough. :slayer:
I don't see how the ASDA oil betters the spec since it has not got the FIAT 9.55535-S1 classification.
Checking the 500 handbook on-line for the diesel it does not explicitly state ACEA C2 in the chart nor does it state it on the write-up in the 2nd paragraph.
But checking the MiTo handbook it does explicitly state ACEA C2 for the diesel...
'The use of products with characteristics that are not up to the ACEA C3 (for petrol engines) and ACEA C2 (for diesel engines) standard could cause engine damage not covered by warranty.
I have attached a copy of the Panda handbook for 'good measure' with uses a DPF and one without, which might go some way towards explaining the contents of the Castol email on a previous posting.
A query has been posted for the OILMAN since I would not be brave enough to put the 'value' oil into a MJ.
As the Multijet engine is also used in Vauxhall and Suzuki cars the fiat oil grade dos'nt cut any weight with me.
Fiat spec!? Thats a good one! Given teh quality of their OEM stuff I wouldnt be trusting fiat spec too much, especially after warranty!
Anyway when i did warranty work they did not even bother looking at the service book for me. To be honest, the official fiat dealer themselves didnt put C3 spec oil in the car,
they just put Agip 5w-40, which is also the same oil my indie uses and they gave me a bottle of that to top it up with, saves me from being ripped off by shell (20 euros a liter!!!!!)
A very valid point. I'm certainly not going all pedantic & start going into the tiniest detail about oil, but slightly off topic there have been similar discussions on here about fuel, & how some wont use supermarket pumps to fill up. Again, although the likes of Tesco obviously don't refine their own fuel, they get it from exactly the same places as garages do.
I suspect if you did a bit of digging, you would be surprised that certain named/branded oils come from the same stable. It's always good to want the best for the pride & joy but I fear there are some go down the route of....it must be a specific product for a specific ailment so to speak & nothing else will do & I'm not talking just oil here. It's nice to have a hobby, just don't drown in it.:D
Considering that Fiat actually made the engine, it probably should. I imagine you'll find that Vauxhall and Suzuki use the same grade of oil that Fiat do....
I wonder what Asda would do/say if you used their oil for a couple of years and somewthing went wrong which was likely to be attibuted to the oil? I rather suspect that they would not be interrested.
The only analogy I can think of is printer ink. Getting very fed up with paying high prices for ink in our computer at home I bought some from a well known shop that sells ink - let's call them "Partridge Hurled". they promise to supply ink which is as good as the official stuff for a significant saving. The ink promptly blocked the printer and no amount of cleaning or going back to proper branded ink would unblock it. End result: wasted cheap ink and a broken printer that Partridge Hurled did not think was anything to do with them.
I'm afraid that I would rather pay a little more for a little peace of mind.
I've used Selenia whilst the car has been in warranty and I reckon I would also continue to use it later on down the line as well.
An alternative view perhaps...IMO it could well help you later on down the line when selling your car. No guarantee that it would of course, but if you can show that you have got full service history, have used genuine parts for servicing and have used the official recommended oil/lubricants, it can only help to convince potential buyers of the fact that you have looked after your car well, and you might be able to get a little bit more money for your car.
will cut no ice with a dealer
but to a private enthusiast, private sale absolutely!
very worthwhile to show a car has been loved/maintained regardless of cost (y)
Probably yes but they don't quote the Fiat grade do they.
Never had any problem with cheap printer ink in any printer, re-manufactured cartridges, yes loads of problems.
And engine wear - the C2 spec allows for about 30% more wear for a 1.5% improvement in fuel economy. As you say, SAPS limits are the same for C2/C3. More details here.
My previous comments were about oil generally, rather than the specific differences between C2/C3 :).
I've no idea why I'm still re-visiting this thread but it was would be an interesting exercise to see what will be the effects if any on using an up-to-date ASDA ACEA C3 in a Multi-jet engine.
From a phonecall with a Supplier and a direct supplier of an oil for a petrol engine that gave 5% improvement in power (Click here) I was advised against using it since it was too new and no one knows what the long term impacts would be.
Re-looking at the C2 spec having 30% more wear than the C3 this was addressed in the 2010 C2-10 spec where the C2 was made 'as good as' the C3 on 'wear protection'. Up to this - Suppliers had stated that the C3 was better than C2.
http://www.lubrizol.com/EngineOilAdditives/ACEA/Sequences/ACEA-C2-10.html
The inclusion of the new OM646LA engine test raises the diesel wear protection performance demanded from ACEA C2 oils.
On the attached comparison 'makeup' of the ACEA C2 & C3, the C2 economy benefits are obvious with a marginal benefit in the 'soot thickening' category for the C3. In lowering the emissions it gives more economy and it will become a trend (Click here). Also it may require more regular oil changes to stop this happening.
http://www.sciencedirect.com/science/article/pii/S0301679X1100315X
Another key difference between a ACEA C3 and ACEA C2 aside from economy is that using a C3 will increase emissions - this could end up been a key factor if you are a borderline case on an a MOT test. At that stage being arsed to change to correct oil might be too late.
Here is a report (Click here - it's a 5meg) of various oils and their performance on a scar test. Quite a few surprises in that a branded oil like Mobil 1 whilst performing well in the economy and power categories didn't do the engine any favours in the 'wear' department. Another lesser know oil did really well given it's price (Valvoline). Oil in the particular spec for the MJ (Valvoline Synpower ENV C2 SAE 5W30) can be got (Click here). Also I would rely on an expert opinion from a reputable supplier & I would suspect that Fuchs, Millers & Motul would come into the short list. It goes to show you that paying top $ for an oil does not guarantee that it's good for your engine. There is also another 'school of thought' that economy oils are not doing your engine any favours (click here). Some experts are recommending to increase viscosity (click here) stating that its ok e.g. to use a 5w40 in place of a 5w30 if it's warranted for cars outside the warranty period.
The issue with having a DPF on the Fiat and it requiring a 'Low ash oil' means that the best performing Esther oil cannot be used. The only one in this category that has some Esther content is the Mobile One ESP 5w30 but I would only consider it on a car requiring ACEA C3. Some of the newer performing diesel engines from 'Fiat' do not need a C2 so that a 'performance' oil can be used.
The last point about the Fiat Approval spec FIAT 9.55535-S1 - although 'nice to have' it's not 'enforceable'. Once you meet the viscosity and ACEA spec I cann't see how a warranty claim could be refused on these grounds.
There are specialist sites out there on oil but to keep it 'simple' I've taken an extract from the AA website where it is clearly states that for a Diesel engine C2 is the best ACEA.
http://www.theaa.com/motoring_advic.../engine-oils-viscosity-and-specification.html
If you have a diesel car fitted with a DPF you must use one of the latest 'low SAPS' (Sulphated Ash, Phosphorous, Sulphur) oils. Using 'normal' oil instead of low SAPS can result in blocking of the DPF.
C1 Low SAPS (0.5% ash) fuel efficient
C2 Mid SAPS (0.8% ash) fuel efficient, performance
C3 Mid SAPS (0.8% ash)
Ach just my sense of humour. I'm an old petrol head , but I'm at the life's too short stage. It is good to exchange information. Forums can be curious places at times, there are moments I wonder who's behind the keyboard...:devil:
Congratulations - you win the prize for least helpful posting of the day. A prize I normally award myself, incidentally.
Thanks PJ.
I would have put a lot of effort into that posting and have realised that the whole topic of oil is a complicated one. If you don't know much about oil it is best to stick with the recommended oil from the manufacture and it you stray outside the spec it is with a 'full knowledge' of what you are actually doing. Over-mapping a car will show it's effects within a year or 2 with a whiney gearbox and some blue smoke puffing out the back. A poor quality or incorrect oil will show up at the MOT stage where many a Diesel have fallen foul at the emissions test either through excess wear on the engine or the increase in NOx from having the wrong oil. My father-in-law's Toyota Avensis 'trusty' Diesel was a victim of that and no amount of tinkering with fuel 'cleaners' and 'turning the power down' could get it past it.
That said I would suspect that the ASDA ACEA C3 will probably serve the OP well & that is the contradiction. In trying to prove him wrong I learned a 'bit' about oils.:)
No problem jimboy. Good handle by the way. I take it that you're the jimboy that stared in 'that series' many moons ago.;)
Well at least I proved your point that the marketing men have been earning their money - it just took a bit longer for me to see through it.
