Technical  oil from Duologic
thom0385
Copenhagen
Hello Forum
I have an issue with my duologic transmission. It shifts gears smoothly, but there is oil dripping from the valve unit located in close proximity to the oil reservoir, meaning at the front. (I assume it controles the revers gear?) Is it the valve that is broken, or is it an indication that there are seals inside the shifting mechanism that are worn out? The specific valve can be seen in this link: valve
Thank you in advance, and have a great day, Thomas.
That isn't a valve it is an electronic position sensor
From what i have read not uncommon for a selespeed fluid leak in the area .
I suggest keep checking level of selespeed fluid and dont let it get too low.
Only use correct petronas selespeed fluid.
It is not a trivial task to change the seals.
If only a small leak not worth doing
