Technical  Need help with the oil filter
tonykuzmin
Lisbon
Hi! Just got a 1.3 Multijet 90cv version 2007, plan to change oil for the first time, but I don't know what filter to use. It seems like there are some variations for this engine.
MANN has 3 sizes
Model
1.3 mj 90cv
Year
2007
Mileage
235000
Yes, I had the same problem, it can be quite awkward when you find take out the grubby filter only to find your new one is not the same.
It might be an idea to order all three and send back the ones that don't fit. Be careful not to get oil on the new ones that are not suitable though.
Two of the filters are quite similar if I recall correctly. This one fitted my 2011 Qubo 75hp JTD
  • OIL FILTER.png.pdf
Just thinking, is it too messy to take out the filter to check its type on a cold engine before ordering?
Is it full of oil?
Yes, it is full of oil. Even when you drip the oil first, there is loads of oil left in the filter. It is messy, a bit. But you can use stuff to collect the oil and make it clean, less messy.
I mean, since the filter is located higher than the sump, shouldn't the oil drain down overnight?
Just checked Shop4Parts, it seems like the 75cv version was supplied with both types of filter and 90cv version only with Purflux...
I don`t know if a 2007 1.3 MJ is fitted with start stop if it is a differnt filter may also be required.
Click on the oil filter tab
You will see 2 options
One ufi
One purflux
If round black filter cover has purflux on it you need purflux filter
Ok, new problem... I can't unscrew the plastic filter housing... any ideas how to unstuck it?
