Technical  Oil filter location
CaradoSteve
Manchester
Good afternoon.can some one,tell me as to the location on the engine were the oil filter is located 2023 ducato 2.2 140 euro 6 motorhome engine thanks Steve.
I do no know whether the filter has migrated, or even if the engine has changed.
For filter location of an x250 2.2, see page 46 of the X250 training manual, which is available in the "Downloads" section at top of page. Select the longer file to download, as the shorter file covers the 3.0 litre engine only.
I did an oil and filter change last year on 2022 auto.
Driver's side accessible from below, and needed a polly bag to avoid a bit of spillage down the sleeve. It's a screw on and the plug/washer is different.
I'll check tomorrow for part numbers but be careful as some suppliers listed the previous model.
Morning.
Sorry bit confused with my 500 yesterday.
See photo. The washer is 10263450.
I reused the plug but part is 55196505. It's got drain holes before you completely remove the plug.
I've put a splash guard on so cannot get an upshot of the filter in situ.
Thank you I will have have a look at the download regards Steve
