General Oil and Wipers
AppleSei
RIP L181 VBB
West Yorks
Searched the forum you think that the words 'oil and seicento' would come up with the answer but alas not.
Ideal oil for Sei MPI Is it 15w 40??
Also need new wipers. Was in hellfrauds and had their brand and some bosch ones to choose from. The boschs were a lot more expensive, any benefits from buying those over the hellfrauds ones?
South Wales
Halfords ones work as good as the bosch ones from my experience.
As far as i know your right about the oil. That's what i use in mine anyway (SPI)
Hope that helps:)
OP
OP
AppleSei
AppleSei
RIP L181 VBB
West Yorks
Well there was 9 quid difference between the wipers wondered what i would be getting for that 9 quid
Ive seen 15w 40 mentioned before hence putting it, put MPI in case it was owt different but didnt expect it to be TBH
Always a great help everyone on here :D
Liam
hi friends :waves:
Scotland
Well I've had my car 4 years and only replaced the wipers once with the Bosch ones and they are perfect still.
Liam
West Yorkshire
smurfhead said:
Semi synthetic 10w40 is recommended for MPi FIRE units. 15w40 for SPis.
Ok, here's one for you....which oil do you use in an 1108 (originally equipped with SPi) thats now fitted with a MPi on a 75 head.... :confused:
I'm guessing 15w40 as the bottom end is the same.
John
Liam
hi friends :waves:
Scotland
My 1108 SPI has been running 10w40 semi synth since I took ownership, I found on the first change it revved alot better afterwards.
Liam
OP
OP
AppleSei
AppleSei
RIP L181 VBB
West Yorks
spi = Single point injection. All cinquecentos and seicentos up to 2001 had this type of fuel injection system in engine
MPI = Multi point injection. All Seicentos from 2001 to end of life had this fuel injection system
F.I.R.E = Fully Integrated Robotised Engine. Basically the engine unit itself
HTH
