Bagofwasps
- Joined
- Sep 28, 2019
- Messages
- 12
- Points
- 55
Recently bought a secondhand Fiat 500 that makes ‘sloshing’ sound behind the dashboard on cold start and hard acceleration. I noticed radiator coolant was a little low (right on the min mark) so topped up to the max line. Later after driving, the coolant had dropped to the min mark again. Thinking maybe the fluid may have driven out some air in the rad, I topped up again to the max mark. After driving the level was back to the min line again and stays there. If it’s a leak why does it not drop below the min line? Really hard to tell if the rad is leaking visually since the roads are so wet recently that the car is permanently dripping wet under the engine anyway. Any ideas? Thanks
