Technical Odd noise
Technical Odd noise
pritch
Bristol
Car is as in my sig. When I pull away there is a slight knocking/rattling noise as the clutch is let up. It disappears when the clutch is let out. It's worse I think when pulling away uphill, or when the clutch is under more duress. It doesn't do it at any other time, except maybe a couple of times letting the clutch out after going into second. I've also noticed a little noise lately when the engine is cold and in neutral, which disappears when I push the clutch pedal down and/or engage gear. Could this be connected? Any ideas appreciated.
Spirito di Punto | M-reg 55SX, black, 5dr.
