- Joined
- Feb 16, 2005
- Messages
- 5,983
- Points
- 988
May be better in LL but I'll try here first.
My fault logger came yesterday adn had 5 faults logged in it, but they may have been from a while back when i was installing the new engine, so I cleared them all and took it for a drive about.
The MIL light isn't on but after the 5 mile drive it lofs P0340, Camshaft position sensor.
has anyone had this fault and got any pointers? I'm going to clean it, check the wiring, etc, and it may be doen to using the wrong ECU but and more tips would be welcome.
I'm hoping to trigger the engine light tonight which happens on the motorway and see what that error is.
Also the software reports TPS at 0.8% when off the throttle, should this be exactly 0% or is this normal, if not, how can I recalibreate it to 0%? I'll try disconnecting the throttle cable and see if it sits a 0%, if not I need to look further into it.
Cheers peeps
Kristian
OT: The hardware is pretty neat, I just need to get some logging software, but seeing all the values on the screen is nice
Cheers peeps
Kristian
