Technical  Now not starting
Fiatinaus
Nsw
Hi Brainstrust
In Australia with a fiat 500 twinair dualogic(selespeed) which had problem with gears after removing gearbox noticed the thrust bearing was destroyed was running fine before it tore down
Replacement clutch installed and now it will crank but will not run (like its misfiring and when it does run its really rough)
Robot was removed from box before removal but put on I assume correctly on reinstall
Have double checked all plugs earths etc
Can't seem to work it out
Please help
Thanks in advance
Model
500c
Year
2013
fiat 500 twinair dualogic(selespeed)and now it will crank but will not run (like its misfiring and when it does run its really rough)
Did you drop the engine oil for this repair ?
Just a couple of recent threads on twinairs:
Anthony H
will check that thanks
The earth is attached to the duelogic selespeed robot and my some used silicone between the robot and gearbox maybe that could be breaking the earth
Did not drop engine oil
only gearbox
Anthony H
only gearbox
The factory earth cable can rot internally,
Try adding a jumper cable..
battery Negative to gearbox
