Technical None Of My Brake Lights Work Fiat Grande Punto
fgp59
:confused: None of my brake lights work, was wondering if someone could talk me through what to do/buy as I have absolutely no idea :eek:
i have a fiat grande punto 59 plate, 1.4 active sport i believe its a 8v
it brakes fine... a little bit squeeky but hopefully nothing major.
Have a look @ fuse F22 oy pedal switch (IO30)
Regards, Bernie
If someone helped You here fix or understand your issue, hit the thanks button, it's free !!
Most likely fault is the switch on the brake pedal bracket. You can check it with a multi meter. Alternatively unplug the switch and short out the pins on the plug that connects to it. If the brake lights come on then the switch is faulty. If not check fuses, bulbs and wiring. I assume rear sidelights and indicator work OK so earth is probably OK.
Robert G8RPI
Thank you... and yes rear lights do work and indicator, its just breaklights and tail light that have stopped, I had an error code sometime in January when i broke down,
and the RAC came out, and come out with this.
RAC DIAGNOSTIC SYSTEM
System Type: ENGINE SYSTEM DIAGNOSTIC & INFORMATION
Name: 350A1.000 - DIAGNOSE - 1.4L - 51 (69)
350A1.000 - IAW 5SF3 CF4 EOBD - 1.4L - 51 (69)
350A1.000 - IAW 5SF8 NATURAL POWER - 8V - 1.4L - 51 (69)
350A1.000 - IAW 5SF9 CF5/EOBD - 1.4L - 51 (69)
DTC: P0504,Brake pedal
DTC: 1220,unknown
Although im hoping i havent been driving around without brake lights since then... it was my partner who told me my brakelights aint working
