1x per week it happens that our uno doesn't start. there are no sounds from starter motor. i can hear fuel pump and all lights work OK. the battery is new. warm or cold doesn't metter and jumping cables doesn't help. battery cables are OK and not corroded. after x turns of the ignition key it starts with no problem.
i suspect it's the ignition below steering wheel because ->
i found out that kids used fuel from poor uno to fill thair motorbike. becouse thay couldn't suck it out directly from the tank thay used some fuel hose from engine bay and put it in plastic bottle. thay didn't wire the fuel pump directly with the battery so thay could have had non-stop fuel flow but thay used ignition key instead. of course in order to fill few bottles thay needed to turn the key at least 50 times :doh:
so is it the ignition below steering wheel?? starter motor was renovated few months ago
