Ok, GP 16V 1.4 65K miles.
Got a rotational noise from the front left. Gets worse as the car gets faster - appears to be related to wheel speed and not Engine speed.
I.e. doesn't matter what gear you're in or whether you're in or neutral - depress clutch.
At 60 mph - you can hear the rotational noise above the radio.
Had two attempts at the wheel bearing and has had no effect.
Garage can't identify where the noise comes from, so what to do next is a bit iffy and potential expensive.
Other bit of info is the front left went into a small collapsed drain on road works on the motorway, and it bent the alloy, 2 years ago, but never got the wheel changed for about 5 months as wasn't noticeable unless at high speed.
Any ideas?
Thanks in antic. Z
Any ideas?
Thanks in antic. Z
