Technical No spark not starting
rgraham72
Hi i am in south africa and have fiat palio 1,2 2001 model ,the problem is it was running fine then it just stop when i try toe start again it crank but not starting and noticed there is no spark on plugs pls help
You can get a scan done at the nearest dealership,
if not then if you want to go via DIY route then I recommend get your self a 3 ping to 16 pin cable to hook upto your ECU , 2) get an ELM Bluetooth scanner and finally install MULTIECUSCAN software and run a scan of your ECU , you will get the exact error code and will be able to pin point the problem ,
you can buy 3-pin cable off ebay.com or your local ebay site ,
also you can buy a Bluetooth ELM scanner from ebay ,
MES is here
http://www.multiecuscan.net/
let us know if you were able to get any where with this ,
maybe the electrical wires or the ignition coils or the crankshaft/camshaft sensors or in worst case the ECU itself has issues, I had similar problem, my car was cranking but it failed to start, I looked down under the car to find a broken belt coming from under the hood, it was later revealed that the snapped belt broke the bracket which holds the crankshaft sensor in place for proper operation, so the car failed to start
Did it stopped working suddenly while you were driving it, or you found that issue before driving the car at all ?
