Technical No keys
Technical No keys
gsc1ugs
Hello
We have a fiat multipla brought in and it has no keys, we are wondering what is the cheapest way to get keys and have the car running again, it is a jtd 1.9 diesel chassis number zta18600002143721. If u need anymore info pls ask any help appreciated. I have been told immoboliser can be deactivated and just get fresh key and ignition barrel is this so?
Immobiliser cant just be bye-passed, plus you wouldnt be insured.
This key would normally have to be ordered from Fiat using Vin and showing ownership of vehicle. 7 to 10 day wait. Then Transport it into the dealer and have them programe the key into the system. That is if the key comes cut to your locks.
Did 1 key work all locks?
Where are you?
If your not local to me, you can send me a door lock and immo box, I can return a pre-coded key, immo box and electronic code that needs to be programmed in using a autolocksmith local to you. If you are local, I can do the programming
This is about a 3 day turn around as apposed to a 7 to 10 day wait from Fiat
so would that key come programmed to the r/c/l and alarm systems too or would it have to go to a fiat main dealer anyway to be programmed to these as well as the immobiliser?
your chassis number starts ZFA by the way.
