I have ben speaking to various people and half understand the concept of what maybe happening with the lack of power on acceleration. I have 2 faults (P0404 + P0046)
I have been told that it may be related to the actuator on the waste gate just under the turbo maybe stuck open and not allowing enough pressure to build up and spin the turbo, or something to do with the boost solenoid.
I think I have located the waste gate and undone the 2 10mm bolts holding it on, but cant work out how to free the actuator, as it is tucked up into the turbo, and I don't know how to get this out. Is there a sure way I can test this in situ...?
And I think I have located the boost solenoid by following the vacuum pipe from the waste gate, and it goes to a small object mounted below the nearside headlight, with a sensor on it. Again awkward to get to... is there a way I can test this, to determine if it is the sensor or the solenoid itself.
Any help would be appreciated..
Chrissib
Chrissib
