Newbie with a tin of worms
Madgoatmotors
Monmouthshire
Hi guys just joined the forum I've got a 13 fiat ducato 130 multijet which I brought from a breakers yard and it's a tin of worms trying to solve the problems 1 by 1
So my 1st problem is the instrument panel has been changed and is from a 2007 van that uses a different bcm so I believe its not compatible. I've got multiecuscan and on the 250 facelift I can connect to the bcm and it shows instrument panel as removed as well as air bag module. I cannot connect straight to instrument panel on 250 FL but if I go to old 250 I can connect using the yellow cable but can't connect to bcm. I'm guessing this is because the instrument panel is missing. Does anyone know a part number for a panel that would work I've tried fiat and they won't disclose the part number for the instrument cluster or air bag module
